Cub Cadet 7235 Front bearing problem
   / Cub Cadet 7235 Front bearing problem #1
thiggs
Missouri
Cub Cadet/7235
Hello, my 7235 bearings in the front right axle shattered it seems that I had a leaky seal. Does any one know where I can find replacment parts + a manual. I live in St. Louis Missouri. I bought the tractor about 2 years ago and it's been good to me so far. Also anyone have a fix for the bolts that loosen up on the frame from the front loader. Thanks
   / Cub Cadet 7235 Front bearing problem #2
You can go to the Cub Cadet website to buy the manual for your tractor. I may have the parts listing for your front end in my manual. I'll take a look later on for it. As for the loader bolts. Here is what I have done with mine. I have the 7275 with a Woods/Cub loader. I found that the present bolts could be swapped out for longer bolts. I replaced all of my loader bolts with longer ones and used Loc-Tite to hold them in. I also have a re-enforcement kit from Woods to stiffen up the loader brackets. I have not had time as of yet to modify my tractor. The Woods brackets are not made for use with a Woods mid mount mower as they claim.
   / Cub Cadet 7235 Front bearing problem #3
I bought a 7234 about eight years ago at the Western Auto in O'Fallon. Ask for Joe Cronin. /forums/images/graemlins/cool.gif
Hi Jim, thanks for the info I have a cub cadet front loader so I'll have to check for any extra frame reenforments from cub. I'll also get the longer bolts and loc-tite. If you can think of anything else that I should look for I do appreciate it.
   / Cub Cadet 7235 Front bearing problem #5
Upper bearing part number MA- 07500563044
Lower bearing " " " MA- 07600051106
Lower bearing " " " MA- 07500263040
Seal MA- 69542-65100
Those numbers are the steering bearings and seal,
The wheel bearings are as follows
Inner Wheel Bearing MA- 07500063050
Outter Wheel bearing MA- 07500063060
Wheel seal MA-08412355212
Flange O-Ring MA-08300501450
If you have a fax number, I can fax you the pages for the front hub and parts listing.
7-NEW INJECTION HARNESS (A55745)
7-NEW INJECTION...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
2018 CHEVROLET SILVERADO 2500HD (A55745)
2018 CHEVROLET...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
