Cub Cadet 7205 Hydro Tranission
   / Cub Cadet 7205 Hydro Tranission #1
Tdelegram
cubcadet 7205
All,
I have a Cadet 7205 with a hydrostatic transmission that is howling and barely moving the tractor. I think the tranny is bad, but i am wondering if this is a rebuildable item and if anyone has any idea's on how much this might run me in parts.
thanks
   / Cub Cadet 7205 Hydro Tranission #2
That doesn't sound good (no pun intended). Still, before assuming the worst have you checked fluid levels, confirmed that you are using the proper fluid, are the filters fresh and the correct ones, etc?
I'm sure that there are others on the forum that can give you more detailed advice for diagnosing your particular model, but be sure that you have not overlooked the obvious things first. I know hydros can be touchy regarding the fluids and filters so maybe you might luck out and find a relatively simple (and inexpensive) solution to your problem. Let's hope so.
Good luck with this - let us know what you find out.
JN
   / Cub Cadet 7205 Hydro Tranission #3
new to tractorbynet....look forward to reading replies and solutions to this
Unfortunately i went through changing all the fluids, filters, adjusting the clutch, and rocker pedal. I have started down the path of stripping the tractor so i can split it in half at the clutch. I think this will be a several month project since I travel 4 days a week and can't work on it every night.
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
American Sanders EZ-8 Electric Floor Sander (A49461)
American Sanders...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2003 CATERPILLAR 420D BACKHOE (A51242)
2003 CATERPILLAR...
2014 John Deere 6125M Utility Tractor (A50657)
2014 John Deere...
