Cub Cadet 7200..20 hp..2000 yr.
   / Cub Cadet 7200..20 hp..2000 yr. #1
kscr4
mid georgia
won't start..battery is charged...removed starter and seems to work fine...turn key to right and dash lights and oil light comes on..turn one more time to right it makes a click sound and every thing goes out... there is power coming to starter..and power to the ignition switch..could the switch be bad?
Help is appreciated!
   / Cub Cadet 7200..20 hp..2000 yr. #2
Sounds like a bad ground connection or dirty battery connection. If battery connections are clean check the other end of negative cable.
Think I found two bad relays..one is a flasher relay..don't really think this was the problem but it was making a loud buzzing sound and the other was a ngk controller relay. Last year my glow plugs went out and I think this is what the problem was..I disconnected the controller relay and the tractor cranked right up..man has this been a night mare...just got to find the relays now..if anyone has a suggestion where to find them would appreciate the help.
Thanks
   / Cub Cadet 7200..20 hp..2000 yr. #5
Jiggle the both levers in the nutral posistion.....couldn't start mine when I first got it and that's all it was
   / Cub Cadet 7200..20 hp..2000 yr. #6
You DO realize that you're replying to a 9-5-2008 post?<g>
Bob B.
2022 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2022 Kubota Z422-54 Zero Turn Mower (A55315)
2022 Kubota...
2010 FORD F-150 (A58214)
2010 FORD F-150...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
Zero Turn Mower (A55853)
Zero Turn Mower...
