cub cadet 6284 engine
   / cub cadet 6284 engine #1
scoops
Bronze Member
Pittsburgh
Can anyone confirm what engine is in the 6284.
I believe it is a perkins 403d-11
Does anyone have a service manual for it?
I've attached a pdf of that engine at 3400 rpm peaks at 21KW, which is about 28hp.
I have looked around on the internet and found a nice pdf file that gives
a ton of specs on this engines and its other familiy members, its about a 15 mb file.
  • 403d-11.pdf
   / cub cadet 6284 engine #2
I don't have any confirming information for you regarding this. I am not aware that Cub made a manual for this engine available. I do know that you need to be careful of the specs in the tractor owners manual. For example, if you follow the manual recommendation for oil capacity you will end up overfilling the crankcase (according to the dipstick which I trust more than the printed spec).
I would be interested in any information that you find - including the file that you mentioned.
JN
   / cub cadet 6284 engine #3
It's a 1.1 liter caterpillar/perkins. Some of the tags on the motor say CAT, some say Perkins. I think CAT owns perkins? 28 HP is the stated value.
My understanding is these engines are used in many other applications.
Unsure about a service manual, I have seen an engine parts manual online.
JN
JN,
If you have an email address, I can send it to you. Its too large to attach here.
Old Machinist, thanks for that info. Even though the servive manual seems to be for the c11, I bet its close enough.
2007 PETERBILT 387 (INOPERABLE) (A45046)
2007 PETERBILT 387...
2016 Jeep Grand Cherokee Laredo SUV (A44572)
2016 Jeep Grand...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A43003)
2015 INTERNATIONAL...
E-Z Trail 3400 Gravity Wagon with Honda EX27 9HP Gas Engine (A44789)
E-Z Trail 3400...
John Deere 5075 (A44501)
John Deere 5075...
Countyline 15 Gallon ATV Sprayer (A44391)
Countyline 15...
