Cub Cadet 417 new control valve is different than old one
   / Cub Cadet 417 new control valve is different than old one
3 years later. Here we are. Tractor has been sitting and I'm back at it. Charged battery and it fired right up. I could not for a control alve anywhere nor any place that could rebuild the old one. The valve control is in my toolshed and all the loader lines are disconnected.
I've decide to say eff' the loader for now and I'll disconnect it the entire loader. It has grader running off the PTO in the back and I'd be happy just having that to grade my driveway and clear snow. So now my new problem. With the 9 lines disconnected to my control vale that ran the loader positions, I no longer have any steering. It must be all hydrualicall ran. I turn the steering wheel and the wheels dont move. Just lovely <sigh> All thos lines must be tied in with the control valve that I can't locate a new one or get it rebuilt.
Also my PTO no longer works and the grader won't operate up or down. Some of the reading I did talked of switching the "flow switch?" to O and hook the P hose to the N hose as it has quick connent fitting. I have no idea where this flow switch is to out it in the "O" position nor do i know what lines at "P" and "N" to connect them (as I guess that bypasses all the loaded lines) I plan to look at it closer today and try to figure this damm thing out. I remember (3 years ago, when I was "playing" with this thing trying to get it going) I found some info in one of the manuals. But I'd like to locate this flow switch, flick it to "O" and see if I can get the PTO working to operate the grader. I also need to figure out what lines run the steering. What a can of worms I got myself into. On a good note, it was sitting 3 years and a charge on the battery and it fired right up. But for now I'm giving up on fixing loader operation and removing the entire thing and focus on getting the grader to operate and get the steering back. Plus it is not very "mechanic fiendly" to get in there and work on stuff or trace down lines, etc. I can't afford thousand to take it to a shop so I'll try to see f I can figue it out.
Any suggestions appreciated. In the 3 years its been sitting I was always searching for another one like mine to look at or even buy the control valve. There's freaking 9 outlets/inlets on it. It's a damm shame because the thing is useless to me and the way it is, it has no re-sale value. Plus I really donlt want to sell it anyway. I'm sure a heavy equipement shop could get it fixed but being on a low Social Security payement per month there's no way I can afford that option.
I took off the loader, it was kind of a pain without hydrualics to change pressure on the pins. I used wood blocks and 2 bottle jacks then backed out the tractor away from the loader. Then supported it with cinder blocks.
As per an online serive manual I found, I switched the box lever from pointing to "S" and opt it to the "O" position, connected the 2 hydraulic hoses that were quick-disconnect fittings. hey were a beech' to connect even after cleaning and spraying them down with WD-40. Finally got it, fired it up and wah-lah, my back grader works. It goes up and down real smooth. Now I just need something nice and heavy to mount on top of the grader blade for extra weight - so it'll dig into the ground. (old engine block, etc)
I'll tackle the loader issue and valve assy later. Hell if I have to I'll just put a few single levers on it to run the loader positions. For the boom, up and down and another one for the bucket to tip both ways. It'll be pretty rinky-dink but functional. <shrug>
Welcome to the Farm Decorative Sign (A55853)
Welcome to the...
2018 Bobcat T750 Compact Track Loader Skid Steer (A55851)
2018 Bobcat T750...
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
2007 CATERPILLAR 420E BACKHOE (A52707)
2007 CATERPILLAR...
2025 Swict 78in Bucket Skid Steer Attachment (A55851)
2025 Swict 78in...
2006 JOHN DEERE 650J LGP CRAWLER DOZER (A52707)
2006 JOHN DEERE...
