cub cadet 3186
   / cub cadet 3186 #11
the vac thing has a rod coming out of it thats threaded. thats where your going to get your adjustment at. i didnt bother adjusting mine though, its really tight.
   / cub cadet 3186 #12
Don't know the age of your machine nor in any changes over the years to how the PTO operates. On mine, there is an electrical operated valve that controls whether vac is applied to the solenoid or not. That part used to be an issue.
Seem to recall I replaced that valve once and problem returned. Next took the valve apart and cleaned it internally. Problem has never returned. Know of several others that also experienced the same problem as I was having. Following my advise their problem went away.
So my advice is to check the vac valve by bypassing it and if the problem is resolved, replace the valve or take it apart and clean. Next if that doesn't take care of the problem I'd start checking for leaks in the vac line and solenoid. There is also the potential for some of the mech linkage to be binding and I'd not overlook that if other items check out.
   / cub cadet 3186
thanks guys for all the help
17101 (A55851)
17101 (A55851)
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
PULL BEHIND SHEEP FOOT COMPACTOR (A52707)
PULL BEHIND SHEEP...
Scag Mower (A50324)
Scag Mower (A50324)
DIRT DOG CP1672 72" AULTIPACTOR (A57192)
DIRT DOG CP1672...
2021 KOMATSU D71PX-24 CRAWLER DOZER (A52707)
2021 KOMATSU...
