cub cadet 3186
   / cub cadet 3186 #1
nolan1
Hi guys my cub cadet 3186 is not mowing very well. When I engage the pto and start mowing the deck basically shuts off once it hits grass, the tractor itself doesnt seem to bog down-just the deck not going and it doesnt do this all the time which makes it even more frustrating. Any suggestions? Thanks
   / cub cadet 3186 #2
Deck belt or tension spring.. gets my vote.. If no belt you most likely have a sheared key in the mower's drive line.
   / cub cadet 3186 #3
Yep, the 3K's use a pair of short V-belts from PTO to the shaft drive. I'd suspect either belt tension or the vacuum actuated PTO isn't holding. I'm not sure how to adjust either on the 3K's though.
Joel
   / cub cadet 3186
ok I will look into those suggestions it just seems strange that sometimes the darn thing comes on like nothing is wrong and then next time I pull the pto engage knob no go
   / cub cadet 3186 #5
i just replaced the pto belts on mine for the same thing. it would take forever for the blades to get up to speed and in high grass they would all but stop. on mine, theres an adjustment on the vacuum thing to put more tension on the pulley. this will buy you some more time on your belts if its not adjusted out all the way already. take your side panel off and you can see the whole thing in action. if the vac is engaging, and the decks not turning, ill bet on pto belts.
   / cub cadet 3186
are the pto belts difficult to change?
   / cub cadet 3186 #7
no, but make sure you put everything back right. i cooked a set that i bought a few weeks ago because i left out a pin. the pto brake wasnt coming off and it cooked the belt. with some simple hand tools you could have it done in 30 minutes taking your time.
   / cub cadet 3186
sounds good ,it appears to be that the tension is very loose so i will try and tighten it then pick up new belts this weekend thanks again
   / cub cadet 3186 #9
if your going to get new belts, adjust it after you get the belts. save doing it twice.
   / cub cadet 3186
thanks I will wait any tips on how to adjust the tension the book does not show this
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2015 CAT CT660 T/A Cab and Chassis Truck (A48081)
2015 CAT CT660 T/A...
2008 Ford F-250 4x4 Reading Service Truck with Liftgate (A48081)
2008 Ford F-250...
Metal Door (A50860)
Metal Door (A50860)
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
