Cub Cadet 3000 Series, Substitute PTO Solenoid/Valve?
   / Cub Cadet 3000 Series, Substitute PTO Solenoid/Valve? #1
Joelk
PA
Cub Cadet 3165(for Parts) 3100, 3206, 3240, 3200 with Snowblower, 5252 with FEL and 60" MMM
I have several 3000 Series Tractors and one of them recently had the PTO Vacuum Solenoid go bad,
I swapped one from another tractor to confirm that the valve was bad.
New from CC they cost about $80 and I will probably need more than one as I plan to keep using 3000 Series for a long time.
I am hoping to find a substitute that is less expensive. I did a bunch of searching on Amazon/Ebay and found many that look like they will work, with some fabrication.
I bought one and it should work, but I will need to make modifications to the wiring to use it.
The CC OEM valve appears to have a GM style Weatherpack Connector.
Has anyone found an inexpensive valve that will work with very little, or no modification?
If so, please provide link/photos/part#s
Thanks, Joel
   / Cub Cadet 3000 Series, Substitute PTO Solenoid/Valve? #2
Thank goodness an l60 commercial Tank replaced the 3235 I had but I think if you take that soiinoid to a napa there is a GM solinoid that matches it. Been six years since I I had it and Ive slept since then!!
I am still looking for a low cost alternative to the OEM part. Any suggestions?
   / Cub Cadet 3000 Series, Substitute PTO Solenoid/Valve? #4
Well for starters, you could give us the Cub P/N and perhaps post a photo of the old one.
Richard
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2004 Freightliner FL70 Trash Truck, VIN # 1FVABTCS64HM47795 (A54865)
2004 Freightliner...
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
Miller Spectrum 500 DC Plasma Cutting System (A55851)
Miller Spectrum...
