Cub Cadet 2284 Tractor Predator engine problem.
   / Cub Cadet 2284 Tractor Predator engine problem. #11
Another option is to move to Florida,, where there are no hills,,,,,,,,,,,,,,,,,
   / Cub Cadet 2284 Tractor Predator engine problem. #12
Depending on the oil level, it could be tripping the low oil shutdown. If you are responsible and check the oil religiously, you could disconnect it.
I used to have a Honda engine on a compressor. If it wasn't very close to level, it would shut down or not start.
Before you mess with the carb, check the low oil switch
Saved me the trouble of typing it. Yes, could be low oil sensor.
Heavy Duty Tire Changer Machine (A55852)
Heavy Duty Tire...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
Kubota LA525 Front Loader Tractor Arm Attachment (A55851)
Kubota LA525 Front...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
Gulf Antique Fuel Pump Art (A55853)
Gulf Antique Fuel...
