Cub cadet 2206 Started Switch
   / Cub cadet 2206 Started Switch #1
Tdraym
Buffalo, NY
Cub Cadet 2206, Kabota 5500
Is there anyway to jump the key switch on my 2206 Kohler command 20, to see if this is why nothing happens when I try to start tractor, yes PTO off, Brake pressed, seat switch jumped. battery good, just looking for leads to try to turn over starter before having to take to repair shop, Tractor ran for an hour while cutting lawn, ran out of gas, wife refilled fuel, called me telling me tractor won't start, 3 hrs. later I came home and tried to start, and it started right up, ran about 1.5 minutes and died. Know does nothing not even click when key is turned, So is the switch bad? Haven't tried check solenoid yet, but will, just looking for help. Thanks
   / Cub cadet 2206 Started Switch #2
Have you looked at the fuses to make sure they haven't been blown. Then check for 12 volts at the small spade or post terminal on the starter solenoid with the key in the start position. If you have power there most likely either the brake switch, or pto switch. Seat switch not normally in the start circuit. the only one I have found to go through the seat switch is scag and some of the older murray riders, but they would still crank and not spark.
Found a wiring dia. on the web showing me power from battery to key switch then pto and brake,reverse switches then to starter sol. Found no power leaving the S blade of start switch, jumped the B and S contact points on the female connecter closing the brake switch and it started to turn over, so I replaced the starter key switch and it solved the problem. the tractor is running again. The problem is there is not to much info on web about Cub Credit model 2206, most of the 2000 series don't even show 2206 models.
Thanks for the help
   / Cub cadet 2206 Started Switch #4
Great, your are in business again. Thanks for letting us know what the fix was. Those switches take a lot of abuse, if you leave your machine out in the rain, it gets in there and corrodes the contacts.
Richard
   / Cub cadet 2206 Started Switch #5
Thanks for the help
I have a WSM for 2000 series tractors. It shows the complicated interlocking of all sorts of switches and relays.
The manual has excellent colored circuit diagrams. For starting, for PTO engagement etc.
Send me a pm with your email and I will send you a link to download my manual.
Dave M704
2017 MOROOKA MST 150”VD (A45046)
2017 MOROOKA MST...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A43003)
2017 INTERNATIONAL...
John Deere 6120R (A44501)
John Deere 6120R...
2016 Mack LEU613 T/A Scorpion Side Loader Garbage Truck (A44571)
2016 Mack LEU613...
10’ WROUGHT IRON FENCE (A45046)
10’ WROUGHT IRON...
2018 Toyota Tundra Pickup Truck, VIN # 5TFRM5F12JX125549 (A44391)
2018 Toyota Tundra...
