Cub Cadet 2185 Pto to Deck belt breaking
   / Cub Cadet 2185 Pto to Deck belt breaking #1
dherro
Does anyone have any Ideas on why my Cub is Breaking PTO to Deck Belts, This is a 1994 model and have had belts breaking with less then 2 hrs of usage /forums/images/graemlins/confused.gif I just recently purchased this Lawn mower it was used. Any thoughts would be greatly appreciated. Thank you in advance.
   / Cub Cadet 2185 Pto to Deck belt breaking #2
Re: Cub Cadet 2185 Pto to Deck belt breaking
I have a 1995 2140 and I noticed that the two lower guide pullies in front of the engine have to be tracking exactly or it twists the belt. I don't know if the 2185 has the same set-up or if this is your problem but it may be a place to start looking. Good luck.
   / Cub Cadet 2185 Pto to Deck belt breaking #3
Yep. Make sure those guide pullies roll freely w/ no wobble or play & be sure the belt is not twisted upon installation. This belt wont last long if it runs flat side down in the front guide pullies.
G/luck
Joel
Thank you for the idea's I will check this out.
D
   / Cub Cadet 2185 Pto to Deck belt breaking #5
Does the belt break clean or does it come off a pulley and shred to pieces?
The break is mostly clean..seems like one edge is a little frayed. Any thoughts?
D
   / Cub Cadet 2185 Pto to Deck belt breaking #7
Hi- Big time probs with my 2185 install- can you send me a pic or typs install info- I am having a time installing a new V- belt- hope your problems work out- I had two blades seized on mine.
Cheers,
"mowin a field in Ontario Canada".
   / Cub Cadet 2185 Pto to Deck belt breaking #8
I had a friend that works on lawn tractors told me a story about the exact same type problem.he found a very small hole in the muffler that was shooting "hot air" right on the belt causing it to break within 2 hours of use.Maybe this will be some help.
Dave
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A51039)
2017 Ram 5500...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
1955 FORD COBRA REPLICA RACING CAR (A51222)
1955 FORD COBRA...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
