CUB CADET 2135 STARTING PROBLEM
/ CUB CADET 2135 STARTING PROBLEM #1
frankski
osterville, ma.02655
new holland ls45
I HAVE A CUB CADET 2135 THAT I JUST PURCHASED. AFTER HAVING MY MECHANIC SERVICE THE
TRACTOR, WE HAVE A PROBLEM HE CANNOT COME UP WITH A SOLUTION TO FIX. THE TRACTOR
WITH HALF THROTTLE AND FULL CHOKE, NEEDS TO TURN OVER ABOUT 30 OR 40 TIMES BEFORE IT
CATCHES AND WILL START. IF I SHUT OFF THE TRACTOR AND TRY TO RESTART, IT USUALLY
WILL START BACK UP AGAIN WITHOUT A LONG CRANKING TIME AGAIN. IF THE TRACTOR SITS
FOR A COUPLE OF HOURS, SAME THING AGAIN AS IF JUST STARTING FOR THE FIRST TIME. ANY
IDEAS WHAT I NEED TO DO? NEW FUEL PUMP OR WHAT. ANY HELP WILL BE APPRECIATED.
FRANK FROM CAPE COD.
/ CUB CADET 2135 STARTING PROBLEM #2
I am no mechanic but it sounds to me like you are sucking air some where. Have you checked all the fuel lines?
Tennant M30 (A64127)
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2022 EZ-GO ELITE...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
