Cub Cadet 2130 Reverse Mowing
   / Cub Cadet 2130 Reverse Mowing #1
Cub124
United States
International Cub Cadet
We just got a 2130 and i wanted to know if anybody knew how to disable the safety switch that lets you mow while in reverse. I don't want to have to turn the pto on and off every time i back up. Any help would be appreciated.
   / Cub Cadet 2130 Reverse Mowing #2
If you do a search on here I believe this issue has been addressed before.....from what I remember I believe you have to remove the mower deck, and there's a pin underneath that has to be kept pushed in....but check the other posts. Good luck!
Thanks i have seen on here before how to do it. they said to disconnect the switch on the left side of the mower, but when i did that the pto would not turn on.
   / Cub Cadet 2130 Reverse Mowing #4
It is probably a normally closed switch, so try connecting the the wires together where you disconnected them from the switch.
Aaron Z
I got it. Thanks for all your help guys
   / Cub Cadet 2130 Reverse Mowing #6
I just bought a used 2135 and desperately want to disable the reverse PTO kill function, can all of you that have performed it shed a little light on the matter. Does it involve bending something or jumping two wires? Details and locations are appreciated.
Thanks
EDIT - I just found the little gray switch (TOO much dead grass in the way) that was hidden pointind downward on the left side of the mower, I popped the dash grill out and disconnected the wiring, pushed the switch through, then re-connect the switch and let it sit under the battery area, this should allow me to mow in reverse!!!
I never thought to just pop the switch out. I just bent the arm out of the way that pushes the switch.
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
2017 Bobcat S650 Compact Wheel Loader Skid Steer (A55851)
2017 Bobcat S650...
2020 JOHN DEERE 333G SKID STEER (A52707)
2020 JOHN DEERE...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2003 Nissan Xterra SUV (A55853)
2003 Nissan Xterra...
