Cub Cadet 1863 Question?
   / Cub Cadet 1863 Question? #1
leftybob
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
Can anyone tell me if the 18 HP Kohler Command engine has a compression release in the engine? When the choke is pulled out the engine gets harder to crank almost like a out of time mode. After it finally starts witha lot of cranking it runs fine.
   / Cub Cadet 1863 Question? #2
My 1864 does this sometimes too, but it's got a 700CCA battery in it so it gets through it :)
-Larry
   / Cub Cadet 1863 Question? #3
No compression release on the engine. Any engine will sound and crank a bit different when choked or at different throttle settings, not sure exactly why this is. If the starter labors just because the choke is out you either have a bad starter (not likely) or a bad battery. How old is the battery, and is it sized right for the tractor?
The battery had been changed to an auto type with top posts before I bought the tractor so it has more cranking power than a lawn & garden battery. It cranks good until the choke is applied. I tried to close the choke about half and it still slows down the cranking.
   / Cub Cadet 1863 Question? #5
Theoretically, closing the throttle or the choke increases the engine vacuum and requires a little more cranking power, but I'm surprised it's enough to notice.
Bob B.
   / Cub Cadet 1863 Question? #6
The Command engines do have a compression release system. From what I understand it is mounted on the camshaft and is a spring loaded rod that holds one of the exhaust valves open a little bit during cranking. I have heard of a few instances where these have broke or worn and that sounds like your case.
-Fordlords-
3014 (A50657)
3014 (A50657)
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2018 Allmand...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
71055 (A49346)
71055 (A49346)
