Cub Cadet 1863 Question?
   / Cub Cadet 1863 Question? #1
leftybob
Bronze Member
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
Can anyone tell me if the 18 HP Kohler Command engine has a compression release in the engine? When the choke is pulled out the engine gets harder to crank almost like a out of time mode. After it finally starts witha lot of cranking it runs fine.
   / Cub Cadet 1863 Question? #2
My 1864 does this sometimes too, but it's got a 700CCA battery in it so it gets through it :)
-Larry
   / Cub Cadet 1863 Question? #3
No compression release on the engine. Any engine will sound and crank a bit different when choked or at different throttle settings, not sure exactly why this is. If the starter labors just because the choke is out you either have a bad starter (not likely) or a bad battery. How old is the battery, and is it sized right for the tractor?
The battery had been changed to an auto type with top posts before I bought the tractor so it has more cranking power than a lawn & garden battery. It cranks good until the choke is applied. I tried to close the choke about half and it still slows down the cranking.
   / Cub Cadet 1863 Question? #5
Theoretically, closing the throttle or the choke increases the engine vacuum and requires a little more cranking power, but I'm surprised it's enough to notice.
Bob B.
   / Cub Cadet 1863 Question? #6
The Command engines do have a compression release system. From what I understand it is mounted on the camshaft and is a spring loaded rod that holds one of the exhaust valves open a little bit during cranking. I have heard of a few instances where these have broke or worn and that sounds like your case.
-Fordlords-
2017 Ground Hog HD99 Towable Hydraulic Auger (A49461)
2017 Ground Hog...
3in Poly Pipe (A49461)
2017 Claas Jaguar 860 Forage Harvester (A51039)
2017 Claas Jaguar...
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
