Cub Cadet 1863 Engine Question?
   / Cub Cadet 1863 Engine Question? #1
leftybob
Bronze Member
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I would like to know if the Kohler 18hp command engine has a compression release? And also if there is any was to adjust the valves? The bolt holding the rocker arm seems to be bolted down solid so I guess it is preset at the factory, and the only way I see it, is to put a thin shim under the bolt. Is this the right way or not?
   / Cub Cadet 1863 Engine Question? #2
Yes, the Command has a compression release, it is part of the camshaft assembly. The Command uses hydraulic lifters in its valve train , and the valve lash is not adjustable. -Fordlords-
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A51039)
2022 JCB 3TS-8T...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2018 Allmand...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2005 Construction Trailer Specialists BDT-40 Bottom Dump T/A 40ft Trailer (A49461)
2005 Construction...
(2) 15X8 RIG MATS (A50854)
(2) 15X8 RIG MATS...
