Cub Cadet 1852 electric clutch wont disengage
   / Cub Cadet 1852 electric clutch wont disengage #1
stewartedward82
Stockport, Iowa
Cub Cadet
Hi i am looking for help with possible solutions to why my electric clutch wont disengage. The clutch switch makes a noise in the clutch, when i flip it and this model also has a reverse shut off feature. any ideas and how to advice on clutch removal is appreciated. i have taken apart the wiring pigtail at the electric clutch and cleaned it. ho do i remove the clutch? do i need to?
   / Cub Cadet 1852 electric clutch wont disengage #2
Welcome from Wisconsin
   / Cub Cadet 1852 electric clutch wont disengage #3
I'm guessing you have an 1862...? Anyhow, go to this link for a manual to help: CUB CADET 1862 OWNER'S MANUAL Pdf Download. for a SERVICE MANUAL , go here: https://www.tradebit.com/filedetail...t-13401535154118601862-factory-service-manual
when dropping that PTO... 1) IT"S HEAVY!! Will take an impact wrench to loosen that bolt that holds it to engine crankshaft. TAKE BEFORE/DURING/AFTER pixs to keep from getting screwed up. Put neverseize on engine crankshaft before final re-assy. Most likely the idler bearing inside the PTO is shot and possibly can be replaced. Get the brg # off the old one's shell - go to local brg shop for replacement - may save $$. Good luck.
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2022 Chevrolet...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
BOAT MOTOR TRAILER (A53424)
BOAT MOTOR TRAILER...
1984 GROVE CRANE (A54607)
1984 GROVE CRANE...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2012 Club Car Precedent Electric Golf Cart (A53424)
2012 Club Car...
