Cub Cadet 1641
   / Cub Cadet 1641 #1
NeedHelp
I can run my cub cadet for a lengthy period of time without any problems as long as the mower deck isn't in operation. When I turn the mower on, the battery begins to run down. I have serveral suggestions as to what the problem is, but no two are the same. Any ideas?
   / Cub Cadet 1641 #2
sounds like, battery -or- voltage regulator -or- stator....Hang a meter on the battery check your voltage while running to see if your charging system is working
   / Cub Cadet 1641 #3
I have a 1641 and had a similar problem. I found frayed wiring near the PTO clutch which must have been causing a power drain when the clutch was energized (engaged).
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
KUBOTA SVL97-2 SKID STEER (A51242)
KUBOTA SVL97-2...
22ft Progressive Finish Mower (A52128)
22ft Progressive...
International 475 14 ft Disc Harrow (A52128)
International 475...
