Cub Cadet 1641 Weak Points?
   / Cub Cadet 1641 Weak Points? #1
phantom printer
Hi, I'm new to forum. Have a Cub Cadet Model 1641 w/48" deck and snowblade. Was looking for a place with tips to keep the old girl running.
Just had to replace the electric PTO (bearing seized). This is 2nd replacement since mid 90's. Normal failure rate?
Also, it has never seemed to have an adequate charging system. Local mower mechanic says voltage regulator weren't very good. True?
Thanks for any input.
phantom printer is online now Report Post Edit/Delete Message
   / Cub Cadet 1641 Weak Points? #2
The owners manual suggests a 100 hr valve adjustment. (B&S Vanguard)
I owned a 1641 that bent a valvestem or pushrod because that adjustment wasn't done.
You might want to look into that.
Curt
Yah, just had a valve job done last year while I had the head off tracking down an oil leak.
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
WOODS 1033674 SUBFRAME KIT (A57192)
WOODS 1033674...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
