cub cadet 1620 mower deck problem
   / cub cadet 1620 mower deck problem #1
docrocky
NW Ohio and SE Michigan
Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
Old machine 32+ years but in good shape with 16 hp Kohler: Mower /pto operates ok but when I lower the deck for close cut, it slows down considerably to almost zero rpm. Where do i begin? Worn belt or tension pulley or ?
   / cub cadet 1620 mower deck problem #2
I would think that you are the right track. If it has been a while since the deck was serviced, pull it out to clean and inspect the deck. Bearings should roll free in the idlers and spindles. The tensioner should be able to work freely to keep tension on the belt. look at the springs for damage and end wear etc.
UNUSED INDUSTRIAS AMERICA SK72 - 72" BRUSH CUTTER (A50459)
UNUSED INDUSTRIAS...
1952 Jeep M38 (A48836)
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
2005 International 4200 Truck, VIN # 1HTMPAFL65H100877 (A48836)
2005 International...
2005 Isuzu FTR Truck, VIN # 4GTJ7F1365F700278 (A48836)
2005 Isuzu FTR...
UNUSED Heavy-Duty Ratchet Load Binder/Chain Set (A50860)
UNUSED Heavy-Duty...
