Cub Cadet 1525 problems
   / Cub Cadet 1525 problems #1
mlewis
cub cadet 1525
I recently purchased a used 2005 Cub Cadet 1525. The tractor is in great shape overall but I am having trouble with the PTO I believe. The blades will disengage after about 20 minutes of mowing. Once they go off, I can re-engage them but then they will disengage every 1-2 minutes. Here is the really strange part. If I sit stationary, the blades will stay engaged. Also, I noticed they will also stay engaged if I only mow at about 1/2 of full throttle or less. If I press the pedal past about 1/2 way the blades disengage again. Also, the blades now stay engaged when I go in reverse, when before the reverse safety switch would disengage them automatically. I ruled out (right or wrong) this being a seat switch problem since it doesn't present itself during the first 20 minutes on the same terrain etc.
I am getting pretty frustrated having to continuously push in/pull out the PTO switch while I mow, or having to mow so slow.
Any help/suggestions on this would be greatly appreciated. Thanks!
   / Cub Cadet 1525 problems #2
How old is the battery? I'd replace it with a new one if it's more than a year old and see if that doesn't fix the problem.
Thanks! I'll give that a try and see what happens.
   / Cub Cadet 1525 problems #4
Since you said the reverse cut out isn't working anymore I'd look at the switch and its wiring. It may have come loose or the wiring may have a rubbed spot shorting out.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
6-row Tine Cultivator (A52128)
6-row Tine...
TMA (A49461)
TMA (A49461)
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52128)
2006 Magnolia Dry...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
