Cub Cadet 1515 won't start after fuel line replacement
   / Cub Cadet 1515 won't start after fuel line replacement #1
monkeywrench77
Upstate, NY
Cub Cadet 1515
Hey,
I just changed the fuel line on my Cub Cadet 1515 and now it won't start. Before changing the line it started and ran fine but I realized the line was leaking so I changed it. After changing the line all I get when I turn the key is a click. The battery seems good as the lights turn on and the digital hour meter works as well. By looking at the fuel filter it appears like it is not pumping any fuel. Any thoughts on what to do?
   / Cub Cadet 1515 won't start after fuel line replacement #2
Sounds like a safety switch is the culprit, not a fuel problem, yet. Clutch switch, seat switch, pto-on switch?
OR, battery cables have the oomph for lights, but not enough for starter? If the click is the starter solenoid trying to make but not getting enough amps, then check cables and battery. If it's a relay or fuel shutoff solenoid clicking, check for a safety switch.
Report back.
Jim
   / Cub Cadet 1515 won't start after fuel line replacement #3
I totally agree with jimmysisson and would add, Check your grounds at the negative battery cable and the solenoid mount. Let us know what you find. 445A
2016 Hyundai Sonata Sedan (A50860)
2016 Hyundai...
Trailer Axles (A50860)
2025 K0608 UNUSED 3-Rail Style Fence Panels (A50860)
2025 K0608 UNUSED...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
2007 Vanguard National VIP4000 53ft. T/A Dry Van Trailer (A48081)
2007 Vanguard...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
