Cub Cadet 128/Kohler K-301 Crankshaft Accessory Removal
   / Cub Cadet 128/Kohler K-301 Crankshaft Accessory Removal #1
jet62095
New England
1968 Cub Cadet 125 Hydrostatic, 1974 Cub Cadet 128, 1961 Hinomoto E-21
I'm trying to remove the front PTO, (Screws stripped) the starter generator pulley, and the flywheel. I bought a flywheel puller, but it will not work as my flywheel doesn't have any puller holes. Do you have any ideas on how to remove these parts?
Thanks for your help,
John
   / Cub Cadet 128/Kohler K-301 Crankshaft Accessory Removal #2
1. front pto has 2 setscrews per hole. Sneaky little buggers.:mad:
2. Crankshaft /flywheel removal. Ummmmm, we always drove two cold chisels as wedges between flywheel and block, BUT NOT TOO HARD.
loosen flywheel nut about 1 turn, then place a second nut on the shaft and snug it gently up to the first. Then with a small sledge hammer hit the second nut squarely. This should loosen the flywheel. Don't hit the crankshaft threads, hit the nut squarely. If you don't use two or more nuts, you will almost certainly snap the threaded portion of the crankshaft. This is NOT a good thing. Think first, smack second.:D
My Front PTO set screws are stripped, Any advice on getting them out? And I will give that a try on the flywheel!
Kubota RTV-X900 Utility Cart (A56857)
Kubota RTV-X900...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
