Cub Cadet 1050 Transmission issues
   / Cub Cadet 1050 Transmission issues #1
melradatz
nelson, wi
2009 cub cadey 1050
I have a 2009 cub cadet 1050. It will mow for about 30 minutes then it is like it loses power and will not go forward or reverse on even the smallest incline. If I let it cool for awhile, then will run good again. I have changed the belt and it still does it.
Any ideas please.
Thanks
   / Cub Cadet 1050 Transmission issues #2
Have you checked for leaks in the transmission area? Have you ever changed the transmission oil? It's a bit involved on our model, but I do it each year at end of mowing season.(a season for us is a little over 100hrs of use) Must remove seat, both the brake and go pedals, fenders/floor pan, and the panel under the seat/over the fuel tank. Then I lift the fuel tank up, and out of the way enough to gain access to tranny fill plug and recovery tank.
Your problem sounds to me like low oil level.....or a fan not working, but it bolts to the pulley...so if it's there, it should be working
PS: Check bottom of tranny for drain plug before taking mower apart....plug is round and is removed with an allen wrench....Bob
MAX MANUFACTURING 28PT500 ORCHARD SPRAYER (A57192)
MAX MANUFACTURING...
2013 Ford F450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A55852)
2013 Ford F450 4x4...
John Deere Hopper Assembly Kit (A56469)
John Deere Hopper...
HAMM HD120HV DOUBLE DRUM ROLLER (A52707)
HAMM HD120HV...
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
