Cub Cadet 1050 Transmission issues
   / Cub Cadet 1050 Transmission issues #1
melradatz
nelson, wi
2009 cub cadey 1050
I have a 2009 cub cadet 1050. It will mow for about 30 minutes then it is like it loses power and will not go forward or reverse on even the smallest incline. If I let it cool for awhile, then will run good again. I have changed the belt and it still does it.
Any ideas please.
   / Cub Cadet 1050 Transmission issues #2
Have you checked for leaks in the transmission area? Have you ever changed the transmission oil? It's a bit involved on our model, but I do it each year at end of mowing season.(a season for us is a little over 100hrs of use) Must remove seat, both the brake and go pedals, fenders/floor pan, and the panel under the seat/over the fuel tank. Then I lift the fuel tank up, and out of the way enough to gain access to tranny fill plug and recovery tank.
Your problem sounds to me like low oil level.....or a fan not working, but it bolts to the pulley...so if it's there, it should be working
PS: Check bottom of tranny for drain plug before taking mower apart....plug is round and is removed with an allen wrench....Bob
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52128)
2019 New Holland...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A52128)
2017 Ford F-550...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
