Cub Cadet 1046 Oil Change - 6 Questions
   / Cub Cadet 1046 Oil Change - 6 Questions #11
has any one had oil bolwing out of the filter no matter how tight ?on a 17.5 briggs moters
   / Cub Cadet 1046 Oil Change - 6 Questions #12
Sounds like you have a defective filter or more likely may have the wrong filter installed. Remove the filter and check the O-ring for proper placement in the groove and no damage. Check that the diameter of the O-ring matches the sealing area of the mounting surface.
Bob B.
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
