I built my house last year and plan on putting in my yard this spring. My property has a 150 foot side hill that is at about a 25 degrees slope with a ditch at the bottom. The incline of the hill is about 50 foot. The only way to mow the hill is by going across it instead of up and down. I really only need a tractor to mow the yard. I have a 4WD ATV that I will use to plow snow and haul a cart. I was looking at the Cub Cadet 1046 ($1800), 2042 ($2600) , and 2186 ($2800). The 1046 is belt driven and the others are shaft driven. The 1046 and 2042 have 20 in rear tires and should be less likely to tip over. The 2186 has 23 in rear tires. The 2042 is considered a lawn tractor by Cub and doesn't have the same attachments for it as the 2186. I was also thinking about putting ag tires with wiper fluid on to help with the traction. Also what is the best way to remove rocks after the top soil is spread with a dozer? Any suggestions or opinions are welcome.
