Cub C60 Engine Rebuild
/ Cub C60 Engine Rebuild #1
jwalker54
Clarendon, NC
Ford 8n, Farmall Cub LoBoy 64 & 72
I am a new TractorByNet member, so bear with me until I get the hang of this.
I am currently rebuilding a Farmall Cub C60 motor and just removed the pistons over the weekend. The reasoning for the rebuild is because I was having a good bit of blow by on the motor. I wanted to see what others thought about if I should remove the crank and the main bearing? I am leaning towards not messing with them because the crankshaft seems to be pretty snug and the rod bearings looked really good when I took the pistons out. A guy I work with says that since I already have the motor removed from the tractor and the engine broke down that I should go ahead and replace them. My biggest thing is that I don't want to spend any more money than I need to. Currently my cost to get the motor back together is; $50 for piston rings, $50 for rod bearings, $90 for gasket kit, $50 for new exhaust valves and a few other odds and ends to button everything up. The main bearings would add another $60 to the price tag. The engine was holding good oil pressure before which is pushing me not to mess with the bearings. What are your thoughts?
Thanks Lou66. I guess I need to go ahead and install the main bearings. I was just wanting to save a buck but I would kick myself if I put it back together and something went wrong with the bearings later on. Thanks for your reply.
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
New/Unused Wolverine 84in Snow Pusher (A65583)
New/Unused...
Morbark M12D (A63689)
