Cub Air Filter
/ Cub Air Filter #11
The "fan" creates a vortex to insure the air flow is moving around the entire filter. Clean it and re-use! We have successfully altered filters to fit our applications. From your description the filters should seat well and with modification will secure just fine. The kubota's larger diameter is a plus as it creates more surface area to keep longer service life.
As long as the micron rating is the same you should have no probelm. If the filter was to fine the Cub Cadet's gas engine (less vaccum) will run rich on you; I tend to doubt you will have a problem, though. Good luck!
/ Cub Air Filter #12
Those Kubbota filters work perfectly. I have been using them in my 7205 for several years now.
/ Cub Air Filter #13
The Donaldson P535362 replaces the 15741-11080 and we sell it for $31.46 online. If you purchased a couple at a time you would reduce your shipping costs and save some money. Just a thought.
Tracy
/ Cub Air Filter #14
We've all complained about the price of filters, this is about the air filter on my 7234 and I think the same one was on the 727X series as well. I called the closest dealer the other day and he gracefully quoted me a price of $88.00 for the filter. I didn't call any others, there aren't many in the my area. I then went to work crossing the CC number: MA-10310511200 to a Wix #46387 and Donaldson P526801 numbers. What was neat about the Donaldson site it also gave the various pieces of equipment it fit, Kubota 1550 and 1750 were a couple. Next I called the Kubota dealer and they had one for $22.51. I just picked one up and it looks almost identical to the CC only you can see from the air slots, the replacement has diamonded slots for the air and the original had round holes. I know we go round and round about using OEM products but I would find it hard to believe that Kubota thinks less of their engine filtration systems than Cub does. For the difference in money I'll use these now that I know the numbers. I believe it is a Donaldson filter, Made in USA, Wix also had one but it was about $10 more from NAPA.
I have 2 Dealer New Old Stock MA-10310511200 Filters in Box
If someone wants OEM Will sell $40 each
chuckstlou@gmail.com
/ Cub Air Filter #15
Just for the record, the LuberFiner (an English brand) LAF8823 will also fit and may be a bit cheaper on Amazon or the like. You just need to drill out the center hole for the mounting bolt to 11/16" for the Cub Cadet thumbscrew like all the other fits-a-Kubota filters.
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2025 AGT Industrial MX-MRT14 (A60463)
2025 AGT...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
