Cub AGS 2130 Runs then stops and won't start
   / Cub AGS 2130 Runs then stops and won't start #1
b bart
I have a cub cadet ags 2130. It will start run 10-15 min.s then stop and won't restart until cool. It has about 400 hrs on it. I though maybe some bad gas I put some sea foam in and it ran the same. Any help would be appreciated. The oil reads a little above the full line. Would that affect it?
   / Cub AGS 2130 Runs then stops and won't start #2
The oil level should have no effect.
Sounds like an electrical component failing as it heats up. :D:confused:
Condenser?:confused:
   / Cub AGS 2130 Runs then stops and won't start #3
No condensor on these electronic ignition Kohlers but the ignition module could be causing the problem. When it dies check to see if you have fire to the spark plug. If you have a spark then I would suspect its a fuel problem like the gas tank vent is clogged. Try running it with the fuek cap loose or off and see if it runs longer.
   / Cub AGS 2130 Runs then stops and won't start #4
No condenser on these electronic ignition Kohlers
Oop's, got my ages mixed up.:ashamed::ashamed::confused2:
12' CONTAINER (A52706)
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55852)
2018 Chevrolet...
PULL BEHIND SHEEP FOOT COMPACTOR (A52707)
PULL BEHIND SHEEP...
John Deere 3025E (A53317)
John Deere 3025E...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
