Cub AGS 2130 Runs then stops and won't start
   / Cub AGS 2130 Runs then stops and won't start #1
b bart
I have a cub cadet ags 2130. It will start run 10-15 min.s then stop and won't restart until cool. It has about 400 hrs on it. I though maybe some bad gas I put some sea foam in and it ran the same. Any help would be appreciated. The oil reads a little above the full line. Would that affect it?
   / Cub AGS 2130 Runs then stops and won't start #2
The oil level should have no effect.
Sounds like an electrical component failing as it heats up. :D:confused:
Condenser?:confused:
   / Cub AGS 2130 Runs then stops and won't start #3
No condensor on these electronic ignition Kohlers but the ignition module could be causing the problem. When it dies check to see if you have fire to the spark plug. If you have a spark then I would suspect its a fuel problem like the gas tank vent is clogged. Try running it with the fuek cap loose or off and see if it runs longer.
   / Cub AGS 2130 Runs then stops and won't start #4
No condenser on these electronic ignition Kohlers
Oop's, got my ages mixed up.:ashamed::ashamed::confused2:
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
434669 (A48836)
434669 (A48836)
2015 DODGE RAM...
Quick Attach 6' Snow Blade (A50515)
Quick Attach 6'...
