Oil & Fuel cub 7264 deisel 4x4
/ cub 7264 deisel 4x4 #1
robert born
hello does anyone have a wiring diagram for the wire that feeds the fuel injection pump solenoid on a 2003 cub cadet 7264 with a diahatsu diesel 26hp please send to me please thank you i dont want to strip the whole harness trying to trace the wire by color thank you
/ cub 7264 deisel 4x4 #2
All the 7000 series diesel tractors share the same wiring and dash. I believe you're talking about the fuel shutdown solenoid and it has two circuits that go to it. The first one is for the pull coil on the solenoid and it fed from a terminal on the starter motor. The hold coil on the solenoid is fed from the accessory circuit from the key switch.
