Cub 7232 spec info
/ Cub 7232 spec info #1
DMB
Louisville, Ky.
Mahindra 2615 gear
Does anyone have or know where the specs for a 1997 Cub 7232 could be found? Is this a Mitsu built like the other 7000 series units I have seen?
Thank You, DMB.
/ Cub 7232 spec info #2
Yes it is made by Mitsubishi. I have an owners manual for it and could copy the specs page for you if you are interested. Here are a few specs on it.
3 cyl diesel 75.36 cu.in.
23 hp.
wheelbase 65 in.
ground cleaenace is 13.8 in.
turning radius 94.5 in.
weight 2139 lbs.
height to top of rOPS 83.5 in.
width 51 in.
length 115 in.
Thanks for the info, a nearby Cub dealer has one as a trade in. A friend of mine is looking for a compact to use as a mower only. His place is mostly flat and open and this used one has turfs and a belly mower, sounds like just the ticket for his needs as he didn't want anything bigger than 25 hp.
DMB
/ Cub 7232 spec info #4
</font><font color="blue" class="small">( Thanks for the info, a nearby Cub dealer has one as a trade in. A friend of mine is looking for a compact to use as a mower only. His place is mostly flat and open and this used one has turfs and a belly mower, sounds like just the ticket for his needs as he didn't want anything bigger than 25 hp.
DMB )</font>
Maybe he might want to look at the 5000 series from Cub?
Its a sub-compact with a 3 pt as well, can handle the straight mowing and meets the HP he was looking for....
Ducati
I'm not familiar with the 5000 series, but I'll pass that on. I assume it can be seen on Cub's website.
Thanks DMB
2017 GEHL RS6-34 TELEHANDLER (A62613)
2017 GEHL RS6-34...
2019 John Deere 6130M (A64126)
2019 John Deere...
Stout Brush Grapple HD72-4 (A66285)
Stout Brush...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
10x20 Barn Style Shed (A62613)
10x20 Barn Style...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
