Cub 3235 power steering failed, all other hydraulics good
   / Cub 3235 power steering failed, all other hydraulics good #1
screamineagle66
Cub Cadet 3235
Three days ago when I mowed, the steering operated correctly. Today, it feels like it has no or next to no power steering. All other functions are good, fluid level is correct. Is it likely the cylinder, or the steering box ?
Thanks for your help.
   / Cub 3235 power steering failed, all other hydraulics good #2
Ist change steering wheel forward or back and see if that frees up steering. If thats the case at the bottom of steering pour some oil around the shaft where it goes into the sleeve that enables you to tilt the wheel. I have used STP seems to last longer. This problem happened to me on a 3265 and after the dealer said I needed a new cylinder I for some reason I pushed up the wheel and GEE I had power steering. this may or may not be yours but----
2007 FORD F-450 (A50854)
2007 FORD F-450...
2016 Ford F-550 Crew Cab Landscape Dump Truck (A48081)
2016 Ford F-550...
1981 Case 245 2wd tractor with bushing (A51039)
1981 Case 245 2wd...
Redirective Crash Cushion Guardrail (A48081)
Redirective Crash...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
2013 Chevrolet Impala 1FL Sedan (A48082)
2013 Chevrolet...
