Cub 3235 power steering failed, all other hydraulics good
   / Cub 3235 power steering failed, all other hydraulics good #1
screamineagle66
Cub Cadet 3235
Three days ago when I mowed, the steering operated correctly. Today, it feels like it has no or next to no power steering. All other functions are good, fluid level is correct. Is it likely the cylinder, or the steering box ?
Thanks for your help.
   / Cub 3235 power steering failed, all other hydraulics good #2
Ist change steering wheel forward or back and see if that frees up steering. If thats the case at the bottom of steering pour some oil around the shaft where it goes into the sleeve that enables you to tilt the wheel. I have used STP seems to last longer. This problem happened to me on a 3265 and after the dealer said I needed a new cylinder I for some reason I pushed up the wheel and GEE I had power steering. this may or may not be yours but----
12Ton Hydraulic Bottle Jack (A55787)
12Ton Hydraulic...
JLG Lift 450AJ Series II (A53314)
JLG Lift 450AJ...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
CFG Industrial MX12RX (A53316)
CFG Industrial...
2021 KENWORTH T880 5 AXLE DUMP TRUCK (A56129)
2021 KENWORTH T880...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
