cub 3235 hyd pump no power
   / cub 3235 hyd pump no power #1
jeff262
I have a cub 3235 I bought it new in 2001-02. It ran great until this summer. About half way through mowing my yard it lost all power. I took the hyd pump a part the gerotor was broke a small section chewed up. I replace the gerotor the internal filter. I clean the valves out the best I could. I put it back together no power to deck lift or trans. Little power to power steering. Is there air in the system and how do I bleed the air out? Is there still metal shavings in the system? Maybe the pump is shot. I appreciate any help. thanks jeff262
   / cub 3235 hyd pump no power #2
Did you install the O-rings and seal correctly. Also check the relief valve to make sure metal particles aren't keeping it open.
Bob B.
   / cub 3235 hyd pump no power #3
Hmmm... dunno. The parts descriptions I've seen on the 2 or 3K series machines show a typical swash plate hydrostatic pump/drive. Didn't know there was a gearotor in there, unless that's the auxiliary pump for the steering and aux attachments.
Joel
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
1984 ASPT 30ft Pole S/A Towable Trailer (A48081)
1984 ASPT 30ft...
2019 Toro Proline 32in Fixed Deck Mower (A48082)
2019 Toro Proline...
2008 Ford Taurus Sedan (A50860)
2008 Ford Taurus...
2013 Fiat 500c Lounge Hatchback (A48082)
2013 Fiat 500c...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
