Cub 2544, 18 hours and my transaxle is leaking!!!
   / Cub 2544, 18 hours and my transaxle is leaking!!! #1
Bucky_O
Westchester County, NY
Hey, gang...
About ten minutes ago I went to unhook my trailer from my 2005 2544, and when I pulled my hand out from under the tow plate, it was covered with a dusty, greasy paste. Apparently, it looks as though the transaxle is leaking from between the segments. With 18 hours on the clock, this has me quite nervous. I didn't have time to check the level (wife was calling me to leave for church) so I was unable to see if maybe the oil is coming from the fill hoe, or maybe from the filter. The machine does not slip or anything.
Anyone have a similar issue?
Thanks!
Regards,
Anthony
   / Cub 2544, 18 hours and my transaxle is leaking!!! #2
Until you confirm where the leak is coming from I can speculate that its not serious - and if I had to guess it is coming from where the filler and rubber gromet (on the axle) meet. You can take the rear cover off, and with that the level and filler tube. My bet is its is leaking from there, maybe because the fluid level is to high....
   / Cub 2544, 18 hours and my transaxle is leaking!!! #3
I AGREE.
Mine was over filled at the factory by at least half a quart! Did the same thing until the dealer drained it and refilled to the proper level.
   / Cub 2544, 18 hours and my transaxle is leaking!!! #4
I thought mine was leaking to BUT I later found that it was grease spatter from the deck and I get the same thing all over after I regrease. I'm sure it's nothing to worry about have you noticed actual drips or puddles under the tranny?
CATERPILLAR 272D2 XHP SKID STEER (A52707)
CATERPILLAR 272D2...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A55851)
2025 HT360W Mini...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2025 XKH39 39in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 XKH39 39in...
