Cub 2180 High Lift Blades or Mulchers
   / Cub 2180 High Lift Blades or Mulchers #1
MrWiggles2
Clarence Center, NY
2004 Cub Cadet 2180
Hoping you fellas can shed some light on the blades. My Cub has the 42" two blade deck and currently I'm running the stock wavy mulchers. I use them when I bag and they do a good job, filling the bags to overflowing. However, now I've been discharging and my cut quality seems to have suffered. If I don't overlap by half the tractor width, I leave a lot of uncut grass. Blades are sharp too. Would the high lift blades work better, do you guys really see a difference?
   / Cub 2180 High Lift Blades or Mulchers #2
My 2042 had the mulchers when I got it. It didn't cut worth a hoot, and would leave strips uncut in the middle. I told my dealer and he gave me a set of hi-lifts. I thought they would do the trick. To my surprise, it wasn't any better.
I always mowed in #6 position since it was the dry season and I wanted to give the grass a fightin' chance over the weeds. But then one day, I dropped the deck to 5 and it sounded like it spun faster. Odd, I thought. I just figured it had something to do with ground effect and when the deck was lower it had less resistance, or just sounded different.
Finally, I got to looking around at it, and noticed that the take-up pulley for the deck belt wasn't swinging far enough over on it's arm to take up the slack. The engine-to-deck drive belt was fine, but the other belt had slop in it that would go away when the deck was lowered to 5 and below. I took it all apart and greased the shaft (it's a half-fast design IMO) and put it all back together. Now it roars even at setting #6 and it doesn't leave any uncut strips up the middle.
Lower your deck as low as it will go, then raise it to 6 without anything running. See how much slop is in the belt that goes around the blade spindles. If it ain't tight, you have the same problem I had.
Good Luck!
I never would have figured that out. Curiously, I was at my dealer today as my Cub is being serviced for a bad regulator and asked about the highlift blades. I was told they don't exist for my Cub. /forums/images/graemlins/confused.gif I just think I was given wrong info actually. Anyway, I'm picking it up later and I'll check out the belt. It could be the same issue.
   / Cub 2180 High Lift Blades or Mulchers #4
I use the high lift blades on my 2042 that came with the bagger, they are better than the 3 in 1 blades that come with the unit. I have not noticed mine missing any strips of grass, but it has been so dry here in VA the grass is not growing so it is hard to say. I guess I'll see if I am having the same problem with slack in the belt once the grass starts growing.
   / Cub 2180 High Lift Blades or Mulchers #5
HI! mr wiggles. looking for some high lift blades part no#742-3017.any cub balde that is 21'' with 3/4in center hole would work! being with in weight,and high to med lift..surprized that your dealer didn't sell you this blade or is he to lazy to look one up for you.also I found out the hard way that your spindle can also get fouled up with grass and dirt, and the big killer fishing string.i thouht that my spindels were going bad .took apart and cleaned the bearing to find little pieces of fishing string all through the bearing.well it cutts like as if it were new sort of! I think it is all about blade tip speed! the faster the blade the better the cut and lift.
   / Cub 2180 High Lift Blades or Mulchers #6
</font><font color="blue" class="small">( ...Curiously, I was at my dealer today as my Cub is being serviced for a bad regulator.... )</font>
Uh-oh.. Say it ain't so! Not a problem with the vanguard!
Hope they getcha patched up.
G/luck
Joel
Thanks GC! I'm going to experiment and try a different blade.
The Vanguard really runs like a top, I love it. Last week the battery barely turned the engine over, it started and ran and I was able to cut my yard. I shut it off, took a broom to the deck, went to restart and it just clicked. I took it to the dealer and they said the regulator went bad and wouldn't charge the battery. Consequently, the battery was toast as I wound up running it down and ruining one of the cells. It would take a charge but wouldn't hold a charge. Nice to be back to normal. /forums/images/graemlins/laugh.gif
Komatsu Midi Excavator (A51691)
Komatsu Midi...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
1985 FREIGHTLINER FLC DUMP TRUCK (A53843)
1985 FREIGHTLINER...
2015 MACK PINNACLE (A53843)
2015 MACK PINNACLE...
