Cub 2135 will not start
   / Cub 2135 will not start #11
You can place a voltmeter across the new battery without the engine running, and check the voltage. It should be around 12-13 volts. Check it again with the engine running, it should increase to the 14-15 volt range. This will verify that your engine's charging system is operating properly.
Just about all modern small engines operate with a magneto type ignition system, using the battery for just starting the engine. This makes troubeshooting battery problems a little difficult. -Fordlords-
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
CATERPILLAR D8T CRAWLER DOZER (A52707)
CATERPILLAR D8T...
2021 CATERPILLAR 259D3 SKID STEER (A52707)
2021 CATERPILLAR...
2014 Chevrolet Tahoe SUV (A55853)
2014 Chevrolet...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
