Cub 1860
   / Cub 1860 #1
NA4D
Greensburg, KY
Cub 1860
My Cub 1860 will start but the engine will speed up, then slow down, then speed up, then die. It will then start right up just fine but start the same sequence again. I have replaced the fuel filter and air cleaner. I took the carb apart and it is clean as a pin. I checked the jets and they are fine. The crankcase line to the fuel pump seems okay. The fuel pump is new as of last year and you can see it pumping fuel up into the filter. It acts like it is running out of gas. Any ideas?
   / Cub 1860 #2
hi na4d,
i'm nowhere close to being a mechanic, but i had a generator doing this. it turned out to be in the governor. i didn't find the solution, a technician did.
   / Cub 1860 #3
"The fuel pump is new as of last year and you can see it pumping fuel up into the filter. It acts like it is running out of gas. Any ideas?"
Install the filter BEFORE THE FUEL PUMP.
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
175 Gallon Spray Rig Pull-Type (A52128)
175 Gallon Spray...
2008 FREIGHTLINER B2 BUS CHASSIS (A51222)
2008 FREIGHTLINER...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
