Cub 1440
/ Cub 1440 #1
Rider1
Stuyvesant, NY
John Deere X300
Good Morning,
I am a new member.
I was recently given a Cub 1440 Hydrostatic garden tractor. It has been in a garage for about 2 years and not been run. I have put in new plugs and the battery is strong. It tries to start, but..
1-I get the message that says that PTO is on. I have disconnected it and still get the message. ????
2-I am wondering if the fuel pump needs replacing.
Thanks
Rider 1
/ Cub 1440 #2
It may be the safety switch is stuck. Also, did you change the fuel? If the fuel has ethanol in it after two years it will be bad. May have to replace the fuel filters if ethanol was used.
/ Cub 1440
Hi dave1708
Thanks for the info and the welcome.
I will be draining the gas tank as soon as I can find a container large enough.
I also talked with a mechanic at the shop where the tractor was purchased. I am going to clean the carburetor.
I tried putting some gas straight in to the intake and it fired up fine.
for the future I am going to use gas that does not contain Ethanol.
I'll keep you posted.
/ Cub 1440 #5
Hi dave1708
Welcome to the forum! Good luck finding any. In my area the only non-ethanol gas available is at boat docks and is very expensive.
Bob B.
/ Cub 1440
Hi Bob,
Thanks for the ideas. I'll check the switch, probably replace it. We have a local convince store chain 'Stewarts" that has ethanol free gas as a possible selection at their pumps which makes it a little more convenient.
(2) New 14-17.5 NHS tires w/ fluid on 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2013 KENWORTH T800 WINCH TRUCK (INOPERABLE) (A65643)
2013 KENWORTH T800...
Frontier Forks (A64126)
Frontier Forks...
LOOK! (A65640)
LOOK! (A65640)
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
