Cub 1440 smoking under load - new issue.
   / Cub 1440 smoking under load - new issue. #1
Mike9
Ghent, NY
Kubota B6200HST-D, Cub 1440, Huskee 4200 LST
Hi - I just serviced my 1440 with Vanguard 14hp. V-twin last week - fresh oil, all filters and plugs. I was cutting the back field today and with the PTO engaged and pushing it up hill it started blowing a cloud of white smoke. I shut it down and checked for leaks then started it up and it ran fine till the PTO was engaged and it was work loaded. I can run it up to WOT and nothing, engage the PTO on level ground and nothing, but in gear smoke. I pulled the plugs and they are not oily. I'm thinking head gasket, but it's air cooled, or could oil be getting in the cylinder because of a blown gasket? I'd like to diagnose it without a full tear down. Thanks for any opinions and help.
It's a head gasket - just ordered the set so will tear down and rebuild next week. Have a great 4th of July.
   / Cub 1440 smoking under load - new issue. #3
How did you determine head gasket? How many hours on engine? Best luck w rebuild.
Jim
Watched several videos on youtube. They all seem to go in the same spot where the gasket is narrowest between the cylinder and the push rod port.
   / Cub 1440 smoking under load - new issue. #5
I have one w 620 hours, curious about your hours. Thanks
Mine has 425 showing, but it used to be my BIL's and he bought it used so what kind of maintenance, or neglect it's had I don't know. My niece gave it to me after he died. It's a nice machine and with new gaskets and regular maintenance should last for years.
   / Cub 1440 smoking under load - new issue. #7
Thanks. This is a good rig and I bought used also. Food for thought. Jim
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
UNUSED FUTURE HYD 12" AUGUER (A57193)
UNUSED FUTURE HYD...
2018 John Deere 1653 (A55315)
2018 John Deere...
2018 KOMATSU D51PXI-24 CRAWLER DOZER (A52707)
2018 KOMATSU...
2018 HINO 268 REFRIGERATED BOX TRUCK (A57192)
2018 HINO 268...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
