CT4xxx HST Series Q & A
   / CT4xxx HST Series Q & A
Also I thought the 4,000 series came standard with a rear hydraulic remote hookup?
Yes, one set is standard, and it is a detent-style. I ordered the second set separately, along with the factory 3rd function kit.
   / CT4xxx HST Series Q & A #12
The actual width depends on the tires. I have R4 tires, and the rear width is really close to 70. I have a 72" box blade so I can blade the full tire track width. Ag tires are narrower.
P.S.
The 72" Bobcat box blade is really heavy-duty. I don't have any worries about that breaking or bending any time soon.
Good point, I'm being quoted R1 tires so each tire probably is a few inches narrower.
   / CT4xxx HST Series Q & A #13
I'm not the most knowledgeable on this but the function that comes standard would it work on a disc harrow that had wheels to raise and lower it?
update - the HSTs have one pair standard. The SSTs have two pair standard.
I don't think a harrow needs any aux hydraulics - just the 3-point lift arms.
   / CT4xxx HST Series Q & A #16
Rear aux remotes were not included with my 2021 4045 SST. I purchased one rear remote and the dealer installed Ansung brand, who I was told is the Bobcat supplier.
I have only 15 hours on the tractor. To date the gas gauge is not working. Morover, SSQA did not connect properly with Mahindra pallet forks (appears to be Mahindra issue). Overall I'm pleased with the the tractor and dealer.
   / CT4xxx HST Series Q & A #17
What is ssqa? I have only heard the bobcat system called 'bobtach' and, thus, assume it will only work properly with other bobcat equipment. I'd not even expect a mahindra attachment to fit.....
   / CT4xxx HST Series Q & A #18
Bobcat's Bobtach system is compatible with SSQA - Skid Steer Quick Attach. Any SSQA can be used on the Bobcats. The locking mechanism seams to be a tight tolerance and is sometimes hard to lock even with Bobcat supplied pallet forks. Mine was tight when new, but generous lubricant and taking the attachments on and off numerous times has it working smoothly now.
   / CT4xxx HST Series Q & A #19
Your question prompted some googling...... Bobcat invented the SSQA standard.
   / CT4xxx HST Series Q & A #20
Coolio! I do like my Bobcat so far.
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
flooring (A55758)
flooring (A55758)
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
Cushman Electric Cart (A55853)
Cushman Electric...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
