Ct450 smokes and shutter's
   / Ct450 smokes and shutter's
dtix, let us know when you get it back if that helped. How many hour's are on your machine, and what model do yo have thanks.
   / Ct450 smokes and shutter's #12
I have a 450 with 52 hrs. on it. It ran great until about 45 hrs. then started puffing and hard starts.
I figured it was a bad glow plug or injector, Dealer told me just to cycle the glow plugs twice before staring. Once your tractor started did it run ok, or did you still have smoke and problems?
   / Ct450 smokes and shutter's #14
It took a lot longer to warm up compared to when it was running well. But it does sound ok after it's warm. Dealer said that under a load it would be fine cuz the engine would be able to burn the extra fuel. He also said to change the engine oil due to the extra fuel flooding the cylinder with the bad injector.
   / Ct450 smokes and shutter's #15
Im curious to the injector fix, I doubt that is my problem. Mine has did it from the first day I picked it up. I have started ton's of 50hp bobcats on lots of dealers and they all start rough, esp the SST models.
I had a 40hp hydro bobcat for a year and aprox 120 hrs and it started perfect.
   / Ct450 smokes and shutter's #16
Tractors coming back from the shop today. They replaced a bad injector and reset the timing. They say it runs great now. Injector was on back order till the end of December but they were able to find one at another dealer.
Well let us know how it starts up. Mine still starts very hard, but i have marked the dipstick to see if there is fuel in the oil
   / Ct450 smokes and shutter's #18
Runs great now. The timing was off as well.
   / Ct450 smokes and shutter's #19
Question is how does it start, and how cold is it where yr at?
   / Ct450 smokes and shutter's #20
my brand new ct235 has the same issue, hard starts knocking etc, my previous ct225(25 HP model) did not have these issues
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
2014 WESTERN STAR  4900 SF FLATTOP SLEEPER (A58214)
2014 WESTERN STAR...
MCCORMICK INTERNATIONAL 10 FEED WAGON (A52708)
MCCORMICK...
