Ct450 smokes and shutter's
   / Ct450 smokes and shutter's #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
I just purchased a bobcat Ct450 with 26 hours. When I start it for the first time it blows out alot of black smoke followed by white smoke and alot of shuttering then it clears out and runs fine. Also the coil light goes out then i start it then it comes back on when its shuttering and after a few seconds it goes back out. Does this sound normal or is there a problem or somthing. Tractor also has new filters. Thanks
   / Ct450 smokes and shutter's #2
I own a CT 235 (70 hours) and yes the diesel blows black smoke and runs a tad rough for about 20 seconds (depends on how cold it is). And yes, your glow plug light stays on after start up for about 8 - 10 seconds and then goes out.
I don't know why the light does this but I think it's normal. I also think all diesels blow a bit of black smoke on start up (at least I hope so!)
I think your machine is probably normal.
Fred
   / Ct450 smokes and shutter's #3
My Ct450 has 107 hrs and has blown black & white smoke after starting ever since I've had it. I am also concerned about the knocking sound from the engine but the salesman says all of this is normal. My older tractor is a gas burner, the Bobcat is my first desiel.
   / Ct450 smokes and shutter's #5
Mine has 70hrs on it now and I have had it in several shops with many things done to it with no success, it starts very very rough and when in the 20's sometimes wont start right away or stalls, my 440 was way better compared to the 50hp cold blooded pig!!!
It seems to me that the 450's really start rough, especially the SST tractors bein the worst, I have no idea why as it seems neither do any of the service techs ive talked with...:confused:
I have some commerical snow contracts to take care of this winter and I can guarantee one thing if my Bobcat lets me down just one time this winter it will be down the road!!!
   / Ct450 smokes and shutter's #6
Here is a vid of mine on a 50*F morning, cold start...
This is how it normally starts, I will post a vid of how it starts when its 30 or so out as soon as I can.
YouTube - Cold Start
   / Ct450 smokes and shutter's #7
My 230 does the same. I find if i manually cycle the glow plug it starts WAY better. I also installed a block heater even though it sleeps inside a garage but it helps because in the winter i dont enjoy smoking up my entire garage.
I've been suspect of a bad glow plug, bad glow plug timer or a leaking injector but either way its nice to see I am not the only one.
Tinman, thanks for the video. Mine starts the same way. It seems to be normal from what I've read. It dont seem normal. Let me know if you ever find out why they start like this. thanks
I was also reading reviews where guys that have kioti DK50SE, and they say they start right up even in single digits. Something must not be right with are 450
   / Ct450 smokes and shutter's #10
I HAD THE SAME PROBLEM and the dealer picked it up to check it out. They found a bad injector (was opening at 1000psi instead of 2000 psi and overfueling the cylinder) and are replacing it . Hopefully it will take care of it.
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
2013 HINO 388 (A50854)
2014 MACK CXU613 MID-ROOF SLEEPER (A50854)
2014 MACK CXU613...
197390 (A50459)
197390 (A50459)
Quick Attach EZ Axe Skid Steer Tree Shear (A51039)
Quick Attach EZ...
1997 EZ S/A Spool Trailer (A49461)
1997 EZ S/A Spool...
