CT445 starting issue
/ CT445 starting issue #1
jgodin
Wabeno, WI
Bobcat CT445
I started my tractor this evening and it fired right up. Got off to let it warm up, before I realized I didn't have the brake locked I started to get off the seat and killed the engine (safety switch). When I tried to start it again it will turn over but not fire. Any suggestions? Forgive me if I'm new, this is my first tractor.
/ CT445 starting issue #2
I did reply to this when you posted it in Parts & Repair forum but here are a few simple steps to check.
First - when it shuts foo like this you must turn key to Off, wait a seconds for the control module to reset then turn key back on.
With key on - Do you hear the solenoid click on? Is the Glow Plug/Pre-heat light coming on in the dash? If you hear the click and glow plug light comes on means both relays are working. If not troubleshoot why.
You did mention there is smoke, which means it is getting some fuel, but may not be enough.
Look at the fuel filter housing and the shut off lever on it. There are 3 positions for the lever (off, run/on, & air for bleeding). Make sure it is in the ON positon. It is possible for the engine to start and run with lever in Air position if conditions are right, but then change to no run or start if fuel level is low or too cold.
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
2022 Kubota SVL97-2 Compact Track Loader Skid Steer (A61572)
2022 Kubota...
2020 Bobcat MT100 (A64126)
2020 Bobcat MT100...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
