CT335 Dead as a doornail
/ CT335 Dead as a doornail #21
Find the wire coming from the ignition switch to the starter solenoid. Set a volt ohm meter to DC voltage. Secure the black lead to a clean part of the frame. Attach the red lead to the wire coming from the ignition switch to the starter solenoid. Turn the ignition key to the start position. Did the Ohm meter register 12 or more volts. If yes the solenoid is bad. If no then the switch is not sending the necessary voltage to the starter. If a lack of voltage is detected connect a jumper wire to the positive battery post. Make sure the tractor is in neutral with the brakes on. Turn the ignition key to the run position. Touch the jumper wire connected to the positive post of the battery to the post on the solenoid the wire coming from the ignition switch connects to. Did the starter engage and spin the engine over? Yes - No. if yes look at the switch. If no look at the starter and solenoid.
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
