CT335 BUCKET HYDRAULIC DISCONNECT
   / CT335 BUCKET HYDRAULIC DISCONNECT #1
RayJavu
Cloquet, MN
Bobcat CT335
I had a ripped o-ring and replaced it with a new one. It still leaks some so I must have the wrong size. I need some help finding a part number and dimensions for the correct o-ring.
Thanks,
Ray
It's the o-ring in the hydraulic quick connect on the hydraulic line to the bucket. There are 4 lines, right hand side, midway, they are color coded, yellow, green, etc.
   / CT335 BUCKET HYDRAULIC DISCONNECT #4
Bobcat part number is 7013280 for o-ring, 7017076 for seal kit. No idea on size.
Hope you pick up on the edit. This is not warrantied information but I think the o-ring may be a number code A, size 113, 90 durometer. For John Deere coupling AM37982 or Parker 4050-2P. Buy and use at your own risk.
A little more for pondering. Hydraulic Coupler O-Rings for 14 316 317 318 42 43
And more for what it's worth, many sights use the nitrile or buna n o-rings.
2016 VOLVO VNL760 TANDEM AXLE SLEEPER (A58018)
2016 VOLVO VNL760...
2020 John Deere 1025R MFWD Compact Tractor (A56435)
2020 John Deere...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
1995 Rinker Captiva 190 (A56435)
1995 Rinker...
