ct235
/ ct235 #41
I am making this thread even longer but I guess this is the right way to go about it. I got around to changing oil and filter today. Sure enough, someone had over tightened both pan plugs and actually broke the aluminum casting. I went to the local O'reilly's and got some marine JB weld. Suppose to be good around oil, etc. I have put one good thick coat around the plug openings and will put another coat when the first one dries good. Sure don't want to think about having to buy a new pan plug the drive shaft would have to be dropped to replace the pan. Thinking seriously about drilling and tapping the two plugs as large as possible to put a smaller bolt with gasket so I won't have to put any more stress on the broken holes. Just screw the smaller plugs out. Does this sound reasonable?
No actually. Over-torqued pan bolts were something I was warned of by my dealer. They had just replaced a pair of pans because of this, and told me to go hand tight then snug another 1/4 turn max. Turns out mine were hardly tight at all when I did my first oil change- so I inquired.
I suppose you could try a 'weld' product, or overdrill. Personally, I'd want factory threads and pan, but I wouldn't sleep thinking of loosing oil while working the tractor. YMMV.
Sorry for this additional headache with your new tractor. BTW, who did the last oil/filter change?
/ ct235
"BTW, who did the last oil/filter change?"
No idea. I have put several coats of the JB weld With the plugs installed. Once that cures good I willl remove the plugs, inspect and go from there.
"YMMV" ? Not good at abbreviations.
/ ct235 #43
If the last oil change was done by a dealer, and they over torqued the pan bolts, you could make a case to have them claim against their Garage Keepers liability insurance to repair your tractor: replace pans, gaskets, labor/parts, etc.
Can you ask the prior owner/ dealer from whom you bought the tractor?
YMMV: your mileage may vary. Google any term for the answer: https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=ymmv
/ ct235
Looks messy and it is but I feel pretty good about my drain plug repair. I will clean up around it a little. JB Weld is easily shaped.
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A61572)
2013 Hitachi...
10' Dozer Blade (A64119)
10' Dozer Blade...
2023 CATERPILLAR 299D3 SKID STEER (A64279)
2023 CATERPILLAR...
Sakai SV505 (A60462)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
John Deere 4440 (A64119)
John Deere 4440...
