CT235 with tons of corrosion around oil cooler lines and plate under battery
   / CT235 with tons of corrosion around oil cooler lines and plate under battery #1
jcims
Ohio
Hey folks,
Have a low hour 2011 CT235 that has a problem with creeping corrosion around the plate that the battery sits on and the oil (?) cooler lines that pass through it. I'm not that worried about the battery, but am concerned that I'm going to have an oil leak/dump when those fittings give way. I recall a thread about this from many moons ago (circa 2012 or so), but can't find it.
Does it make sense to replace the fittings going through that 'plate' with something aftermarket? I'm not really worried about the battery itself and I'm assuming that Bobcat hasn't re-engineered this part for better corrosion protection.
Thanks in advance for any suggestions
   / CT235 with tons of corrosion around oil cooler lines and plate under battery #2
I changed my stock bobcat battery right away after I noticed it was leaking acid into the battery compartment. Happened mostly when I would get the tractor a A little unlevel.
I caught it before the damage got too bad but it was corroding out the battery tray very quickly.
   / CT235 with tons of corrosion around oil cooler lines and plate under battery #3
Clean the area well and spread baking soda around in the area - will help neutralize the acid
   / CT235 with tons of corrosion around oil cooler lines and plate under battery #4
   / CT235 with tons of corrosion around oil cooler lines and plate under battery #5
James (K0UA) told me about it as well, I think 6-7 years ago, I had just changed the original battery and + power cable, purchased the NO-OX and applied it.....
I just checked it a couple days ago, and still no sign of corrosion.
Some really smart people on TBN
   / CT235 with tons of corrosion around oil cooler lines and plate under battery #6
Battery that came with My Kioti CK35 leaked all over the place when mowing started to corrode everything up front. Pulled that piece of junk sanded and painted everything then replaced with a optima red top and haven't had a bit of corrosion since.
   / CT235 with tons of corrosion around oil cooler lines and plate under battery #7
   / CT235 with tons of corrosion around oil cooler lines and plate under battery #8
When I ordered mine it came in two 8-10 ? Oz cans, doubt I will ever need to order again, maybe my grandson can use the excess up when he inherits my stuff!
   / CT235 with tons of corrosion around oil cooler lines and plate under battery #10
Likewise.
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
INOP/NON-RUNNING 1999 Isuzu NPR-HD Cab and Chassis Truck, VIN # 4KLC4B1R5XJ001370 (A57453)
INOP/NON-RUNNING...
10' CONTAINER (A52706)
LOT: (3) Adjustable Steel Racking Sections, 9' W x 24" D x 56" H (CONTENTS NOT INCLUDED - DELAYED (A59076)
LOT: (3)...
9ft Reading Service Bed (A57453)
9ft Reading...
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV4NPNJ0430, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
